5th wheel position in 05
B&W Turnover Ball and Firestone Airbags installed!
How many amps can the 7 pin connector handle on an 05?
My 5th wheel hitch in my 00 was dead center over the rear axle. Should I mount it the same in my 05 or stay a few inches to the front of the rear axle. Anyone hitch up their 05 yet that can give me some info . Thanks. .
I had always had mine mounted in front of the axle 4inches. However when the dealer had mine installed they put it centered over the axle, it doesn't seem to be a problem. Mine was also welded and I personally called DC and they said that it would not void my warranty.
Do you have a SWB or LWB. If it's a LWB, 2-4" forward of the axle works well, but with a SWB, you need all the clearance you can get, so over the axle is better.
You can go on Reese's web page and get the exact measurements from the rear of the bed to the rails.
Different for Ford, Chevy and Dodge.
Bill Davis
When I weighed my truck at scales, without 5wh, the front weighed 4850Lbs. The front axle rating is 5200lbs. I have my 5wh hitch set up centered, in middle slot of mount. That way I can move it to coexist with the front axle rating.
