5th Wheel Wiring Harness?
Almost new FULL set of tires and wheels, also brake discs
Trans. or Diff. Splitter
I am in process of getting a 5th Wheel Wiring Harness for my 2011. I see that Reese, Curt & Valley have them.
Looking for recommendation or experiences with them.
Thanks in advance.
Joe
Be aware that the 4th gen trucks have gone to the same plug as Ford and GM on the back of the 7-pin connector. I ordered the old-style Dodge harness and wound up having to hard-wire it (which is OK, but not what I was planning on).
Rusty
Rusty
I had the very same thing happen, Hard Wired, works fine, but not what I wanted also.
Rusty & RonD, Thanks for the info. Looking at pictures on the web for the Curt 56000, it looks like round connectors.
Where did you place the RV connector in the bed?
Thanks again
Joe
Low on the side wall of the bed, driver's side rear. Makes it easy to plug in standing on the ground with the tailgate open as I'm starting to back under the 5th wheel.
Rusty
Thanks again
Joe
On the drivers side at the top just forward of the center stake pocket, easy to reach with the 5th wheel connected.
Hi hope this will help, I just made a pig tail on one end of plug from bed to factory plug on the bumper, plug in when I use my fithwheel unplug when tow with bumper. no spliced wires to worry about.
Thanks MikeBeal, I have a cable now but sometimes I pull a trailer when using the Truck Camper. On my '96 CTD I had cable hard wired. Just trying to avoid hard wiring.
Joe
Joe
I used the Lance receptacle for my Lance since I wanted to utilize Lance's 8-gauge wiring and didn't want to tie up the truck's 7-way trailer receptacle. I used the 4-way trailer receptacle under the truck's rear bumper for the Lance receptacle in the truck bed which furnishes tail lights, turn signals, and brake lights. The only hard wiring I had to do was solder/shrink wrap a connection into the backup light circuit for the camper near the 7-way trailer receptacle. The rear docking lights on my Lance are powered through relays from the camper batteries, not the truck's back up light system. Fortunately, I don't have a TIPM to worry about. :cool:
Bill
Thanks to all for the feedback. I ordered a Curt 5th wheel wiring harness.
Bill I like your connection with the docking lights, will definitely look into that. I do not have the Lance connector. I will have to look into that. I like the thought of having an 8 gauge wire feeding the camper. I don't think a standard RV connector/plug will take an 8 gauge wire.
Thanks again for all the input.
Joe
Joe
No, the standard 7-way RV receptacle won't take an 8-gauge wire. You might be able to stuff in a 10-gauge. Also the 12-volt charge wire in your factory harness is too small to effectively charge your camper batteries.
Bill
Bill
Bill, good information.
Thanks
Joe
Bargman makes a pigtail for all the trucks, works fine. Like plug and go, no splicing. Most people are mounting it in the rear of the bed on the drivers side.
One thing I discovered on my '02 is that the 7-pin marker parking circuit has it's own fuse and relay (because who know how many lights are on your trailer) but the 4-pin is wired straight into the truck parking light circuit. (Great fun until I figured out it was two circuits and once I replaced the trailer fuse it was all good. ) Naturally my camper plug was connected to the truck parking circuit by a previous owner but that's fixed too.
Bill
Bill, with regards to the 8 gauge wiring. How/where did you put a fuse to protect it?
When I got the Lance, the Lance connector (truck side) was missing. So, I just spliced in a 7 pin rv plug to the Lance. Already had a 7 pin connector in '96 for my 5th wheel. I like the idea of the 8 gauge wire.
Thanks
Joe
Joe
I connected the 8-gauge wire through a 40-amp circuit breaker, mounted on the firewall, to the driver side positive battery clamp. I also ran an 8-gauge ground wire from the Lance connector directly to the negative driver side battery clamp. I didn't want to depend on the factory frame/body grounds.
Our Lance has a built in automatic battery disconnect switch so it wasn't necessary to install a heavy duty relay between the truck battery and camper to prevent discharging the truck batteries when the engine wasn't running.
With the 8-gauge wiring, I can successfully run the 3-way fridge on 12-volts while traveling. The fridge remains cold and no flame blow out problems traveling on windy days.
Bill
