I think it is time to have some technical specs for oils. So here are the specs for the AMSOIL SYNTHETIC 5W-30 HEAVY DUTY DIESEL OIL. (Series 3000) Perhaps AMSOILMAN will double check these properties. The technical properties are from bulletin G-1301 8/96.
1. KINEMATIC VISCOSITY @ 100 Deg C,cSt (ASTM D-445)= 11. 50
2. KINEMATIC VISCOSITY @ 40 Deg C,cSt (ASTM D-445)= 66. 00
3. VISCOSITY INDEX (ASTM D-2270)= 170
4. COLD CRANK Simulator Apparent Viscosity @ -25 Deg. C, cP (ASTM D-2602)=3150
5. POUR POINT (ASTM D-97)= -60 DEG F.
6. FLASH POINT (ASTM D-92)= 460 DEG F.
7. FIRE POINT (ASTM D-92)= 489 DEG F.
8. NOACK VOATILITY (DIN 51581) 250 DEG C FOR 1 Hour, % weight loss= 7. 8
9. HIGH TEMP/HIGH SHEAR VISCOSITY, cP, 150 Deg C, (ASTM D-4683)= 3. 61
10. FOUR BALL WEAR TEST,40kgf, 150 DEG C, 1800 RPM, 1 hr. , scar diameter, mm (ASTM D-4172)= 0. 39
11. TOTAL BASE NUMBER= 12
12. FALEX TEST = ? I will update this when I get more info on this test.
This oil exceeds all current API and SAE requirement specifications including:
*API CG-4, CF-4,SJ
*ACEA/CCMC D-4,D-5,PD-2
*MIL-L-2104F
*CUMMINS NTC 400
*U. S. MILITARY GASOLINE ENGINE OIL (API SH/MV/MA)
*DAF SHPD
*DETROIT DIESEL 7SE 270
*M. A. N. 271
*MACK EO-L, EO-K/2
*MERCEDES BENZ AG 227. 1, 228. 1
*SCANIA LONG DRAIN
*VOLVO VDS LONG DRAIN
*VW 505. 00
*ALLISON C-3,C-4
*CATERPILLAR TO-2,TO-3
CONCERNING THE FOUR-BALL WEAR TEST COMPARISONS from best to worst: (WEAR SCAR DIAMETER IN mm. )
1. AMSOIL SERIES 3000 5W-30_____________0. 39
2. DELVAC 1 SYNTHETIC 5W-40_____________0. 431
3. DELO 400 15W-40______________________0. 599
4. ROTELLA T 15W-40_____________________0. 683
5. CUMMINS PREMIUM BLUE 15W-40__________0. 707
If any of you have other oils to add to the FOUR-BALL WEAR TEST let me know and I will add them to this chart.
I am not an AMSOIL dealer but have used Amsoil for over 20 years mainly because of seeing the benefits of Log Trucks using Amsoil Lubricants in our area and seeing the results in my own vehicles and tractors. If any of you folks out there find an error let me know so I can upgrade the chart.
For the 15W40 AMSOIL SYTHETIC MARINE & DIESEL OIL SPECS see the post from amsoilman.
99 QC Diesel,5spd, white,Luverne SS step bars, Mopar long mud flaps, A. R. E. cap with walk thru door, SS rock side panels, JC Whitney front bumper 14" guards, BED RUG box liner, diamond plate bed rail and bulk head covers.
[This message has been edited by Eino (edited 01-23-2000). ]
*API CG-4, CF-4,SJ
*MIL-L-2104F
*CUMMINS NTC 400
*DAF SHPD
*M. A. N. 271
*MACK EO-L, EO-K/2
*SCANIA LONG DRAIN
*VW 505. 00
*ALLISON C-3,C-4
