yesterday i put in the new nozzles.. i popped my stock #1 injector and it was about 3800psi... added a .5mm shim and it went to 5000psi... settled on .15mm shims and 4500 psi is where im at... i checked each one before installing it and all came to 4500 with the .15 shim... accept #5 it was at 4500 psi with no shim... the engine now sounds more even... it smokes less and has more power... I put my AFC in the middle and it was not enough fuel so slid it forward where I had it with the stock nozzles ... I can tell the extra pressure bumped my timing back a little ... overall on a couple of short drives im very happy... these are 145 degree VCO 5X.012 from DAP... they were great to work with ...Im running a 16cm housing on my HX35 and hit about 38psi with the new 5X12 nozzles .. Ive been looking at turbos... the S300 62 68 14 looks good but at $1000 + - the HX40 is starting to look pretty good at half or less used... Ive read up on them and most I see are pretty close in size to the S300 I mentioned ... I can just get a diamond eye DP to connect to the rest of my 4 inch exhaust and Im done... Ive read some snapping shafts on HX40 chopping the throttle with manuals... I barked my turbo a couple of times yesterday with the converter locked by accident so Ill have to watch that ....
any input anyone has would be appreciated
thanks
JAK
thanks
JAK
