your 83 should have as mentioned,a thermal controler on back of the drivers side head unplug the wireing harness,somestimes the little pins in the controller that match up to the plug get corroded and cause probs,simple clean them and reinstal plug. however if the controller is bad or you simply want to greatly extend the life of your g plugs,go with a push button setup. steps for push button control are. 1 unplug harness from controller,simply leave it off,it has no other function. 2 the solenoid on the drivers fender has a plug with a pink and a bluish wire going to it ,leave these alone, on the same solenoid there are two lugs on each side,both should have wires goin to them. get two pieces of wire approx 3 ft long {fairly heavy wire} put lugs on them that are capable of going over the studs that are on both sides of the solenoid ,run one wire from each stud to a suitable place inside the trucks cab,connect these two wires to a push button{you will most likely}need smaller lugs on these wires,so you can attach them to a push button . use a button rated for aleast 15 amps. when you push the button you simply close a circuit,and send fire to your glow plugs. 8 to 10 seconds is a rule of thumb on button times,between cranking. sence you have done away with the factory settup,expect the truck to smoke a bit longer upon startup. also chk to make sure you still have good g plugs,sometimes when a controller fails ,it can burn out the plugs. to test the plugs ,simply run a jumper wire from the hot battery post to the tab of the glowplug itself,no spark =bad plug ,weak spark= weak plug,strong = spark good plug... .
