Check the harmonic balancer, if the rubber bonding between the outer and inner sections is chipped, cracked or perished, crankshaft failure will be imminent if not replaced asap.
Unfortunately, it will be hard to check the main bearing webs in the block for cracks, which were common on the later low nickel content blocks, without dropping the oil pan, however, 6. 2Ls have run for over 100K with those cracks, so it's not too worrying.
The inj. pumps are usually worn out at 100K and the injectors are best replaced between 50-75K.
The timing chain is a major PIA and causes pump/cam timing and power issues. Replace it at 100K with dual idler timing gears.
A Banks or ATS turbo is recommended for getting practical power from this engine, along with a DB2-4911 pump and 6. 5LTD injectors.
Mine had over 270K on it and it was turboed at 240K without problems. I ended up fitting it with a Banks Ford 7. 3L MHI TE06H turbo and was very pleased with the power. However, I recognized the 6. 2L or even the 6. 5L wasn't going to be up to reliably putting out 400HP at wheels, so I sold the drivetrain and have commenced a 6Bt conversion.
