No, I don't find them noisy at all. If I had the money, I would upgrade to Toyo AT2 or BFG ATKO. I had an '04 Chevy that came with Transforce tires, and they were the worst OEM truck tires I ever had. They had no grip whatsoever on a wet surface. It was nearly impossible to ease away from a light without them spinning, never mind if I'd try to jump out into traffic. The tread pattern appears to be different on these, and I am hoping they have changed the compound through the years.That is a nice looking truck.
What do you think of the Firestone tires? Do you think they are noisy? I think I can squeeze another year out of the tires on my truck and was wondering about the Firestone Transforce tires. I think I can get a decent deal on a set through work.
Good to hear.
How have you found the mileage to be?
Sorry I missed your earlier post about the nighttime dash lights. Not sure if there is a way to dial it down or not. I may or may not have found one of those settings in the radio.
Over the weekend while perusing the net I saw a video by a truck magazine that shows the 6.4 engine Hemi getting slammed by the GM and Ford gassers. The idea of the test was to pull the same amount of weight up I-70 in Colorado and see how they performed against each other. Apparently Chrysler let the computer govern the power of the motor and transmission shifting so it doesn't overheat and overheat the transmission. I think they are just saving on warranty claims as this truck "on paper" should have ran quicker than the other two. How embarrassing for RAM! I had high hopes for this combination but now it seems the 6.4 Hemi will be labeled the proverbial "turd" when pushed to it's outer limits. This would be a good place for the after market to develop an override of this feature.
Here is a link:
http://www.tfltruck.com/2014/10/2014-ram-2500-hd-6-4l-hemi-and-gear-hold-feature-ike-gauntlet-video/
I-70 is brutal going over Eisenhower - either direction - and they are spot on if you are under 45mph and you need to get in the left lane to pass a semi doing >30 - you're hosed.
At the time, I did think it was stupid to move the dimmer, and, while I do like the flash-to-pass feature, I am embarrassed to admit that every now and again my left foot goes fishing for that dimmer switch LOL. We actually had a '72 F-600 that had a foot operated windshield washer with a little bellows on the floor and a "douchebag" on the inner fender. I'll have to admit it kept working after the electric pumps went bad in both '76 F-250s we had.How about the moron's that took the headlight dimmer switch off the floor and put it on the turn signal stalk! #@$%!
I can complain about anything![]()
Like the 2 old guys in the balcony on the muppet shows. I loved those guys.
Now if anyone asks what are muppets I'll I'll I'll complain about you too.
What was the original post about![]()
