6.4L not offered in F-650/750
COLD! start-ability
New Info on future CTD
Page 9 said:
: Cabs may require removal to allow R&R of the
diesel engine. Wire harnesses and other aftermarket
modifications should be designed so the
cab can be removed for engine removal and
installation.
I really like this:
Page 10 said:
Optional Rapid-Heat supplemental cab heater is
available for vehicles with a 6. 4L diesel engine.
It provides warmer discharge air temperature to
allow the vehicle interior to heat up more quickly.
It includes a 200 Amp (67D) extra heavy duty
alternator.
Quick connects for the cooling system? That might be nice.
Page 11 said:
Quick connects replace conventional hose
clamps for improved serviceability and better
leak prevention.
It says that the Cummins 6. 7 is painted red. Is it also painted red for the Dodge trucks?
Ryan
So what does that tell ya?
Your buying a class 5 truck with a class 3 engine. Plus the way Ford defuels the engine it will be gutless. No one makes boxes for a Ford based Cummins.
I have driven a 650 with a 24 valve engine. I was lucky someone else owned it. I would have been very annoyed to have payed money for it myself.
personally i dont like the 7. 3/5. 9 or the 6. 0 in a medium application,under most circumstances. none of them are suitable from a power or longevity point of view. keep the power down,and you can get the job done,aswell as have a engine that will last a while. i have seen many 7. 3 engines last 3/400k in medium duty trucks like wreckers/box vans and buses. but in a medium used at full work load frequently,forget it. the 6. 4 will hit the ford medium line at a latter time,but production has to meet ih and ford pickup requirements,before the ford mediums get them.
