The thickness of the 6. 7 is a major difference
Bob
The seals are the same dimensions. As previously stated, the 6. 7l filter is taller than the 5. 9l filter, hence the difference in part numbers, and manufacturers. Currently, there is no Fleetguard filter available for the 6. 7L. The 6. 7l engine requires more airflow than the 5. 9l, so the stock 6. 7l filter has a larger surface area than the 5. 9l filter. The AFE filter is not a stock filter. It's flow characteristics are much different than stock filters. The seal area/dimensions are the same as both stock filters (5. 9L & 6. 7l), so it is considered a replacement for both. The AFE filter allows much more airflow than either stock filter, so thickness is not an issue.
Hope this helps.
~Andy
Yes that helps.
Basically you are saying the seal dimensions are the same but there is more surface area of the paper element on the 6. 7L filter?
In a pinch you could put in a 5. 9L filter if needed and wouldn't have any fit issues, just reduced air flow.
Either way I will be ordering some Mopar filters from you later today.
Thanks.
Obviously, you'd want to try to avoid restricting air into the engine by using a lesser flowing filter. But, if you were in a bind, a 5. 9l filter in a 6. 7l engine would be better than no filter at all. Which brings to mind another question. If the AFE fits both boxes, why couldn't a stock 6. 7l filter be used in a 5. 9l truck. It would offer factory filtering ability, but also allow a better air flow, since it has a larger surface area? I'll have to do some investigating...
~Andy
~Andy
Good thought. Except for the 6. 7L filters costing more it could be a good way to go.
Don't get me wrong. I'm not suggesting this as a substitute for a hi-flow performance filter, such as the AFE. But, it may allow more air flow than the thinner, earlier model, stock filter - if it even fits the box.
If you change your air filter once a year, at the cost of a stock filter, you've spent enough to buy an AFE filter in three years. Change the filter more often, and the cost benefits of a reuseable filter really add up.
~Andy
If you change your air filter once a year, at the cost of a stock filter, you've spent enough to buy an AFE filter in three years. Change the filter more often, and the cost benefits of a reusable filter really add up.
~Andy
