6.7L and fuel additives?
Bio-Diesel maybe not so good?
wvo filtering
Alright , just thinking about this here with winter around the corner.....
Can you or can you not run fuel additives?
I understand you can run LSD if need to but ULSD reccommended... . I also understand that as winter nears the fuel stations start bringing in winter blend fuel... . Well from what i've been told is sometimes there winter blend isn't always good enough. (Extreme cold like Canada, Alaska some of the other northern states)
After doing homework and asking around i guess ULSD would Gel before the LSD will due to the fact that they took out all the good stuff from the fuel... .
Well if we can't add fuel additives and are running ULSD what are we supposed to do to keep from Gelling in extreme cold? There's gonna be alot of gelled trucks if we have to just go by what the book says. .
Whats your take on this??? :confused:
