Newbie here I hope this is the right location for this type of thread.
Never owned a diesel before until June 1st 2007, but I have worked/driven Fords and Dodge 5. 9L diesels that belong to freinds and family helping them with various repairs and add-ons.
I can see that the 6. 7L will be a challenge for us all, and I am currently playing catch-up.
I am trying to install gages on this engine and truck, and found that the boost bolt that came with the kit measures . 875" inches long. That is from the base of the head to the end of the threaded shank. I checked in on some of the other types that are being offered and all are with in . 100" of each other. These bolts only allows a few threads to be engaged in the manifold, should be at least a bolt diameter of engagement for the threads and torque. Torque is only 12 Foot Pounds with the Boost Bolts. The boost bolts are for the inside/inboard row for the intake. The forward most bolt is the most accessable with the EGR tube shroud removed, next would be the bolt aft, at or about #2 injector, as long as the hex portion is not much
over . 500" inches in diameter and . 750" in heigth, which will require some creative thinking/tools in how to torque this bolt at this location, getting around the rail and injector lines.
The 6. 7L intake/spacer/maniflod stack-up requires a bolt SHANK length of 1. 200"-1. 250", I was unable to locate a boost bolt that was of the proper length for this stack-up, and I will have to have one milled for this/my application.
I have passed this information on to a few companies that supply boost/gauge kits, so they can properly suppy for the 6. 7L engines.
As for the fuel pressure gauge/isolator, I have some fittings and 1/2 fuel line on order. Pyro not installed or drilled yet. Play time has been short resently.
Sorry no pics yet.
Hopes this information helps!
More to come as I dig.
301 miles so far.
First oil/oil filter/fuel filer change 254 miles, running Delo 400LE/Fleetguard Premium filters. No fuel adds.
Thanks
Sorry no pics yet.
301 miles so far.
Thanks
