I have had wonderful results with REDLINE and AMSOIL synthetic fluids in the past, so I am pondering a full conversion. The engine oil and Front/Rear diffs are easy choices, but what about the trans case and NV5600??
I have been told that the trans case needs ATF. Could I use a premium ATF like Redline D4?
What about the trans? Some have said you need motor oil, but why couldn't I use Redline MTL? It has the right friction modifiers in it so the synchros work right and everything.
If you are using a premium FULL synthetic fluid (AMsoil, Redline, Neo-etc. ) in your 6 Speed and/or trans case, please reply and let me know what you using, and the results you have had.
TIA!
TIA!
