6 Speed Clutch Replace, Fill the Blanks
laycock overdrive?
Cool site
I need to replace my clutch and have searched the archives and back issues of the TDR. However, I have not been able to find a comprehensive list of options. Help me fill in the blanks to make an informed decision. Add any pros or cons that you may have also.
So. Bend
Max torque_______
Cost _______
Available Where______
Luk Gold
Max torque________
Cost ________
Available Where
Sachs
Max Torque________
Cost ________
Available Where ________
Rebuilt/upgrade Factory
Max Torque________
Cost ________
Available Where_______
Others?
2001. 5 ETH 3500 6spd. 4x4 quad cab,3. 54LSD,all avail. opts. incl. leather,s. s. fender trim,s. s. bug guard,Stull running boards and custom flaps,line x bed liner, BD injectors plus ISSPRO EGT and Boost, pillar mt. ,Eze Edge,Jardine 4" ex. ,Reese class 5 hitch,Custom overload springs
McLeod dual disk street
Tested before each ships at 800 ft. /lbs, I believe I'm above that now, zero slippage.
About $1300. 00
JVD 877-948-4050
Have a nice day #ad
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
SouthBend 2001 CON FE.
Basically a beefed up new OEM
around $850 If you can get someones good cores call Peter at South bend to find out his current price to upgrade it. (around $450 includes new throwout bearing and pilot bearing)
The pedal pressure stays the same
Uses original flywheel
I believe the warranty is 12 months or 12,000
Great Customer Support
Other members are reporting over 400hp with no problems.
One to consider if you are staying under 500hp. . although no one has tested to slippage yet that I have heard about.
"Have you driven OVER a phord lately"
2001 2500 BRT WHT SPORT QUADCAB 4X4 ETH 3. 54LSD TRLR CMPR PKG ALL OPT XCPT LTHR
