6 speed cooler?
Let me tell you about some TDR members!
2003 Ram / Engine Choice?
My Brand "F" had a cooler for the 6 speed manual transmission lube. Do we need to worry about this on the NV5600? If so, any good kits out there?
Thanks, I did a search but came up empty...
2001. 5 4X4 HO Quad Cab 6 spd LWB, all the normal toys
I talked to Mopars1 this weekend he has a external transmission filter on his, to do this I cant see why you couldnt plumb a cooler into the mix. just keep in mind it would just migrate through it unless you use a pump to circulate it. unless there is a pressure point to tap into... #ad
Todd,
2001 Q-cab SB 4x4 5spd 3. 55's, A pillar Boost/EGT,Jardines 4" turboback kit,custom built aluminum airbox W/K&N-RE0860 through the cowl, and more to come...
For some reason I keep thinking that Geno's sells a small cooler that bolts onto a PTO hole just like their filter kit does.
-Mike
