My 2001 with 6 speed has, since new, intermittently had a problem in going into gear from neutral. It has gotten gradually worse, and now, at about 30,000 miles, it has done it so bad that I could not get into any gear but reverse, and it would grind going into that, and even repeatedly, all the while the clutch was held to the floor.
So, either pilot bearing or hydraulic clutch circuit has been my thought. The dealer has the transmission out as of yesterday. The pilot bearing looks perfect, and still has grease in it. The clutch parts look fine, but that, of course says nothing about the slave cylinder and related hydraulic circuit.
What they say they are going to do now is take the transmission apart, which I think has no purpose, since the noises this thing makes indicate the input shaft of the transmission is turning when this intermittent symptom occurs. The maddening part is that it is intermittent.
It never does it when cold, only when hot, and then only when having been run in city, stop and go traffic.
My best guess is that there is something going on with the group of parts made up of the clutch master, the lines, and the slave, all of which are affected by... . what... . underhood temperature?
Any thoughts on this? Thanks, as I am running out of warranty, and I would like very much to get this fixed on Chrysler's dime, particularly since it began during the first month I had the truck.
