6 speed should I or Shouldn't I
Tow hooks
toolbox
I've got 240,000 hard miles on my 2000 duelly 5 speed, 4 trannys ,2 rearends. Question is, Should I do the NV5600?
IS the 6th gear an overdrive like the 5 nv4500. Am I going to have the same problems?
6th is od but not held by a nut as the NV4500 is. Given the cost of conversion and your mileage, etc. I'd strongly consider trading up to a 2003-305 hp-6 speed. This also gets you the newest version of the NV5600.
Just made the swap from the 4500 to the 5600 in my 98. 5. I think the gears are the same ratio in 1st and 6th but are spaced much better in between. Mine had a big gap between 2nd and 3rd that was corrected with the 6 speed. The swap is pretty easy. Call Keith at Blumenthals in Ok. City, they offer the trans. and the installation kit.
