Dumb question, but need some reassurance here since I do not have the service manuals. Where is the filler hole on the 6 speed transmission? Was told it was on the drivers's side of the transmission and you needed a 17mm allen wrench to get the plug out. Well, I took the 17mm plug out and got at least a pint of fluid all over the garage floor. This hole is only about a third of the way up from the bottom of the transmission and almost appears to be too low to hold much fluid. Owners Manual says the fluid level should be within 1/4" of the bottom of the filler hole. So, if there was that much excess it makes one wonder if I am checking at the correct location. There is another plug high up on the rear section of the transmission, but it would be tough to add fluid there.
Thanks in advance.
Thanks in advance.
