Competition 60 ft times and 1/4 et
Competition water/meth help!!!!3500 dodge (after shock)
Off Roading Axle Identifying??
rockjeep73 said:
13. 66 @ 96, 1. 76 60'. Oh ya, thats only at 352HP
13. 60 @ 98, 1. 91 60'------how much boost you leaving the line with? I think I launched with around 12-15psi on that run... I still have a stock output so I'm kinda sceered to build any more.
Launching at 15# of boost I am usually at 1. 78 60' times, and about 12. 49 1/4 mile E. T,and 109mph. My 60' times all depends on what the track will hold. The better I can hook up, the more boost I can leave with. I left with 20# boost and ran a 12. 34 @ 111mph, on a sticky track, a couple of weeks ago. It was a 1. 71 60'.
Hope this info helps...
Paul
Launching at 15 psi nets 1. 75 to 1. 76 60 foots and 13. 0 timeslips Launching at 20 to 23 psi has gotten me a best 60 foot of 1. 66 when it hooks. The timeslip was a 12. 84 on that pass. Most of the time it will not hook consistently on the higher boost launches.
TJ, I agree with this, the higher boost launches start yielding inconsistent 60' times due to traction issues. Generally speaking, anything in the 1. 6? is pretty darn good, 1. 7? may be more realistic for your setup. I know Tim is happy with most 1. 6? for a solid pass, anywhere from 11. 50's to 12. 20 depending on whether or not he is spraying and what kind of shape the track is in. Sounds like your truck is running pretty good.
Craig
Thanks for the input guys.
Thanks Craig it running pretty good for being on 37's. I was just trying to see about where people are at with auto as I'am new to the club. :D :D
TJ
1. 62 7. 62/8th mile at around 89mph. I usually leave around 18lbs of boost. I have never ran that 1/4 but I'll have to get around to that. Some good sounding times out here.
Dual EE said:
That is a very nice 60' time. What are you using for traction aids w/15#'s launches. Slicks?
Thanks!
Running M&H Nostalgia slicks, ladder bars and QA1 rear coil over shocks. If I try to launch at much more boost than that the 60 ft times are slower.
GotBoost2 said:
Thanks!
Thanks for the info. I can't leave w/anymore then 2-3#'s of boost. Need to play w/my tire pressure a bit. I have been running about 40-45#'s. At what point does lowering your tire pressure hurt your e. t. ?
