Getting ready to install a Pacbrake. Is it worth the extra time and $$ to install the 60lb springs? How much extra braking power do you really feel, esp. running an auto transmission? (yes I have a TC lock-up switch). What is the best valve spring compressor tool to use?
Forgive me for stating the obvious, but if you have an automatic transmission, are complaining about poor exhaust brake results and don't have a torque converter lockup device, without some mechanism to lock up the torque converter when the exhaust brake is in use, the exhaust brake will develop very little braking power but will develop a LOT of heat in the transmission fluid due to torque converter slippage and fluid shear.
Rusty
Rusty is correct. Without a manual torque converter lockup switch, the exhaust brake is useless except for heating transmission fluid.
Grinder,
If your early style PacBrake is vacuum operated you will need to look up the instructions for cleaning the electric/vacuum valve in the TDR archives when the exhaust brake sticks. Carbon will eventually build up in the little valve and cause the exhaust brake butterfly to stick in one position. The valve can be disassembled and cleaned in spray brake cleaner, lubricated, and reassembled and it will work again like new.
If your PacBrake is air operated, you won't encounter this problem. The air cylinder operates the butterfly faster and with more force.
I kept mentioning 60-lb exhaust valve springs, but I don't remember since Cummins did the job. Cummins Southern Plains may have replaced both the intake and exhaust valve springs. They were selling/installing PacBrake exhaust brakes at the time which was several years before Cummins introduced their E-brake.
Bill
You get around 180 HP of braking and it really worked great, would slow down when towing down I 80 from Reno to Sac. If traffic was not bad would never need to use service brakes.
I have the old style brake, w/o a mystery switch. It's pretty disappointing the amount of braking effect I get out of it, and am considering yanking it. Thanks for all the great posts in this thread.
