6860 Miller timing kit question
Gas gauge
ABS & Break light stays on
My 6860 kit is supposed to include spacers which fit on the shaft while re-setting the timming (P/N 6862). My kit came with the 6862 and contained 6 flat washers. The TSB18-10-94 calls for a bearing and washer P/N 6862.
My question: should my kit have included a flat roller bearing and washer instead of 6 flat washers?
1995 4X4 std cab 12 valve, original owner, 100k miles, 14cm turbo, 4" straight exhaust - gutted kitty, EGT and Boost guage, #5 torque, 215 injectors, (370's and delivery valves on the way) AFC spring kit, Pscotty airfilter, Dunrite TC and Red Butt Engineering Torqueflite TransButtyy shift kit, 3. 54 rear, 17. 5" American Racing aluminum wheels, Mickey Thompson MTX's, Rancho's RS9000's, Helwig anti-sway, Starcraft camper and assundry dodad's. Only thing faster than a 12 valve is my Ducati 4 valve
At Auto Wurks Diesel, we use an electronic tool for setting timing. Unfortunately, we can't measure the wild injection on the race pump with it, so we use the dial gauge method. I never saw, nor used the bearing and washer method that the service manual recommends. What I do is set it up and measure the timing, pop the gear off the shaft, turn the engine about 1/2 inch harmonic balancer travel in the direction desired (to advance you want to turn the engine backwards which is clockwise with the barring tool), then clean off the shaft with brake cleaner and lock down the gear with the nut and snug it good, but don't torque it until you measure it and see where you are because you may have to do it again. Caution, the pump also will spring back a couple degrees once over the 12. 5 mark. Be prepared to compensate for it. Finally torque the nut to spec. We use 160 ft/lbs. #ad
Chris Timochko
1997 5sp 4X4, HX40, BD 4" Brake, Marine Compression, Custom Tuned Injection Pump, 370B Injection Nozzles, Delivery Valves, Governor & AFC Spring Kit, Psychotty Air, Water Injection, NOS Diesel Kit, 6" Chrome Exhaust System, No Smoke Valet Switch, McLeod Dual Disc Clutch, Mag-Hytec Rear Cover, Cummins Chrome Kit, Optima Red Tops, Hadley Bully Horns, Hurst Line Loc, Goodyear Wrangler AT/S 305/70/16s. Test mule for Auto Wurks Diesel race program
DleselB59,
Do you take the gear all the way off the shaft so that you can clean it?
Also, how do you keep the shaft from rotating do to spring pressure on the pump cam?
Thanks
At any timing setting really over 10 degrees, the cam of the pump will snap back to a neutral position, which you'll have to overcome by turning the engine a few degrees more. Just pop off the gear and pull it as close to the front cover as possible, then use the little hose on the brake clean can and spray around the shaft and inside of the gear a couple times and you'll be fine. Leave it oily and it will slip timing on you while driving.
Chris Timochko
