6CTA 8.3 Swap
Mirror Interchangeability
anti-lock brakes
Anyone out there tried swapping in the 8. 3??
I imagine it can be done, the 8. 3 is not much larger than the 5. 9 and only weighs about 500lb. more. Air bags or stiffer springs for the front... ... ???
I talked to a guy that was going to do the swap once. He measured a first gen truck against a second gen truck. It will not fit in a second gen truck without extensive firewall surgery. However, he said it will sit right in a first gen truck. If I could find a longbed, extended cab 91-93 4wd truck, I would do the swap and make a better pulling truck. That's too costly for me though.
What are you guys NUTS??? The 5. 9 is rediculous as it is. Next thing you know your gonna want to bomb it too. #ad
I know I'm hangin out in the right place now. :D
