6x6 Ram, no dually
What do you see???
Happy Birthday Blackcloud!!
Don't know if this is the right forum, but thought... ... . it is a 2nd gen,..... without a diesel... ... . why not:D
It is a custom built 6x6 Ram with a V10 in it. For more info, click here
I would have choose a differnt color, but that just me, :D
Andrew
Yuk, yer right, that color stinks, I wonder how well those bars would hold up if that thing happend to flip over? Kinda cool though.
Later,Rob
Looks like someone copied the T-Rex concept truck Dodge had on tour about 5-7 years ago. I saw it at the rally in Sturgis, S. D. Have pics somewhere. It had a 9' bed with 6 wheel drive like the one shown here.
That was where the guys got the idea from what i read. i think it is a lot more intresting when some guys do it rather then a HUGE auto maker.
Andrew
Cool... they are going to run it in the tough truck race thing that one of the 4x4 mags runs... . read all about it on Dave Fritz's site.
Pretty neat truck... it was built by Daniel from
USA 6x6
The truck is running 2. 5 ton toploading rockwell axles with 6. 72 gears and I belive detroit lockers is all 3 axles...
Luke
Think power. Think traction. Think about all the possibilities should the think tank at Chrysler offer this 500-horsepower, six-wheel-drive Dodge Ram for sale to the public. They call it T-Rex; short for Technology, Research, Experimental vehicle.
This 6x6 was conceived, designed and built with minimal investment in about 13 months. Among the innovations that make this concept truck potentially realistic is how power is delivered to the three axles. To handle increased power, torque and payload capacities, new transfer cases where developed. Chrysler engineers used a new external rear transfer case and availabLe production axles. The t-case delivers available torque equally to the two rear axles. An output shaft powers the second axle and a chain-driven over-the-shoulder propshaft delivers power to the third.
A new transfer case was developed for power distribution at the front axle as well. The front t-case incorporates a differential with lock-up feature, a 2. 72:1 low range and electric shift. In six-wheel drive, 48 percent of available engine torque output is delivered to the front axle and 52 percent to the rear t-case -- an arrangement that provides full-time four-wheel drive to the rear axles and full- or part-time six-wheel drive with the front axle locked in.
Speaking of power distribution, Chrysler's rolling platform is motivated by an eight liter, high-output Magnum V-10, modified to boost power from 350 hp at stock specs to 500 hp at T-Rex specs. Power was increased with high-compression pistons, a billet crank, ported and polished heads, modified camshaft and tubular headers. Torque goes from 450 lbs-ft to 600 lbs. - ft.
A standard four-speed Dodge Ram V-10 automatic transmission was strengthened to handle the increased power,torque and payload ratings. Payload rapacity stands at 5,000 lbs. now, with the potential for more. Current towing capacity is 19,000 lbs. , with a goal of increasing it to 26,000 lbs. of Gross Combined Weight.
Ride comfort is handled by an adaptive air-suspension system located by trailing arms and track bar with automatic load leveling and driver-selectable ride control. For ease of entry and ground clearing height adjustment, T-Rex can be adjusted from inside the cab. The truck bed measures eight feet, six inches using Kevlar-carbon fiber composite material on the outer sides of the stretched cargo bed.
T-Rex may well be the world's first fulltime 6x6 designed for personal use in a light truck. Off-road mobility is improved, not only by greater tire patch surface, but better traction due to the power distribution of two transfer cases. Turning radius is tighter than traditional duallies by two feet.
Because this concept truck was designed using supplier-available parts and with cost-of-production considerations in mind, the reality of seeing this truck on U. S. highways may be closer than we think. Think positive.
The green one has potential, but lacks detail. I think they could have put more time & effort doing the wheel openings in the bed too. The str8 across cut looks terrible.
Tim,
If Dodge offered that truck for sale to the general public, at a reasonable price, they would be as hot of a seller as the PT Cruiser.
Amen to that Bill-I'd sign up for one tomorrow if they were gonna make it! I've patiently waited ever since that concept was unveiled-don't look like it's gonna happen though. Bummer... ...
Jason
J hanson We now have the Patented Axles
Thanks All for the comments and you can see the truck in detail on Dec Cover of Four Wheeler Mag
Saw it in the past 6 months at Auge's Dodge in Belen NM. They had an "old" Mopar gathering and this version of T-Rex was there. Looks better in person than on paper. Owner did a really nice job building it and is a down to earth kinda guy, too.
Since Stan is here in NM, he'll probably show up at the 4th Annual Sandia Showdown at Auge's Dodge in Belen NM on 12 Oct. Y'all need to come on over and be part of the fun... ... ... ... .....
6x6
In my unlearned opinion the question is -Why?- unless you are filming Jurassic Park IV. I get gouged enough at the toll booths with the dually another axle would be interesting at toll time on trips. Nice to look at but the benefits outside of Hollywood escape me. But mind you this is coming from someone who cannot change oil. :) :)
