Rosco, I felt the way you do. I wanted the 7 pin in the bed, but do not like splices either. This is what I came up with:
I went to the local auto parts place and bought a Reese 7 pin connector kit with the female plug and comes with about 4' of the 7 wire loom ready to go. Next buy a male 7 pin connector and put them together to make a "jumper" or extension plug if you will.
The Reese kit also came with a metal mounting plate as if you were going to mount their plug under your bumper. I mounted their mounting plate underneath the truck, up and out of sight from the rear, on a conveinent existing bolt. Disconnect the factory 7 pin plug from the bumper, and mount it into the Reese mounting plate you just installed.
Next plug your male end of the jumper into the factory plug, and run the new 7 pin connector that is on the end of the jumper you just made, to the rear side wall of the truck.
Presto! You are done, you have no splices, and and every thing is factory tight. Total cost was less than $40. 00, it's easy to do, and you know it's done right. (The price even included the cost of an additional 7 pin connector that I used to fill the spot in the bumper where the original factory 7 pin connector came from. ) It's clean, easy, and takes about 1. 5 hours... ... . Good luck, Sarge.
