7-way plug colors question?
pulling ford tow truck
camping world
on my 01 ,with the towing package,i installed a 7 way plug in the bed side. wasn't sure which wires to splice into at the frame so i've been running a long length of 7 wire with a male plug on the end and connecting in the plug under the bumper. anyone got the color codes so i can splice it in right below where i put the plug in the bed? i could do it with a test light but figured this would be easier. thanks
7 pin plug
I have a hard time with the electrical dwgs. but it looks like on 99 3500 it is:#1 Ground, black #2 elect. brakes, lt. blue. #3, tail lights, bk. /or. #4, 12v charge line, rd. /or. #5, lt. turn, dg. /rd. #6, rt. turn, br. /rd. #7, backup, vt. /bk. bg
:)Hey, Stop by the Potline tool crib in the morning before you get off, I'll give you the paper so you can get a better look at the 7-way connector wiring diagram. I will be there about 05:45.
**ICEMAN**
Let me know what you find out so I can do it also. I've just been running an additional cord I made up from two plugs, between the trailer connector and the hitch plug, using a bungi chord to keep tension on cord.
i found it in the set of 01 service manuals i have(the big books)
overlooked it the last time i checked it. lots & lots of wiring diagrams in there.
right turn:plug is brown-truck is brown/red
left turn : plug is red- truck is dark green/red
back up lamp : plug is yellow- truck is violet/black
brakes : plug is blue-truck is light blue
ground : plug is white-truck is black
charge 12v+ : plug is black- truck is red/orange
lights/parking : plug is green- truck is black/orange
plug is: 7 pin from the camper
truck is : colors of wires that run to the truck plug from the factory
