According to BFG and Michelin websites here are the following for revs/mile for stock vs 315/70 AT's
Stock - LTX a/s 265/70-17 = 657 revs/mile
BFG AT 315/70-17 = 601 revs/mile
Assuming your speedo is correct with the stock tires (mine is nearly perfect) you are going to be 657/601 = 1. 09 times faster than indicated on the speedo (9% faster). If you want to go 70, your speedo should read 70/1. 09 = 64 mph.
Best and easiest way to double check is use a gps.
Mathew
