Need help for those that don't know and may want to help I will try to explain what I am dealing with. A White industries multifuel with Bosch America rotary head Injection Pump.
The Injection pump gear is bolted on with three bolts and a big washer with three holes. It has been a few years sence I had one off but I don't remember a tapered fit or if there was a trick to it. I remember them pretty much just falling off when you took the bolts loose. This one did not. and as I tapped on it with w hamer it did not move, prying between teeth to "walk" it off with the direction of the gear teeth did nothing either. I even turned the motor over with the starter thinking it might pop off and it did not, didn't even slip on the shaft of the injection pump. I took the pump loose and tried to pry evenly on the pump and tap the gear and Inj. pump shaft.
As a final measure I tapped two chissels about the same amount in top and bottom, used about a 3" 3/4" drive socket on an extension and wailed on the gear try and pop it off. I don't have a torch on site or else I would have heated it. Then tapped more aggressively on the chissls and removed the socket and wailed on the inj pump input shaft, I know this is not good but I figuered the force was between the gear and shaft. Other than the chissels force.
I don't seem to have deformed anything I didnot keep hammering and hammering as it may seem. Try something and tap, try something else and tap a little harder. Two hours later and your fixin ta be swingin that BFH, I went home instead.
Any help would be apreciated
