Hey guys,
I purchased a 73' Brave on a Dodge chassis-RM-300 - the RV is in bad shape and I paid next to nothing for it but was told it ran well. It will idle all day long in park and run as if brand new. As soon as you place any load on the engine it sputters badly and stalls. It will then immediately re-fire and sometimes if I play with the manual choke, it will kick in and go... ... ... but only for a short burst. It appears to be fuel related at times but also sounds like an ignition failure. It has a new cap and rotor and wires and I just replaced the ballast resistor. Still not any better! I sprayed carb/choke cleaner and that appears to have helped. Do I try a new coil and/or fuel pump or get the carb rebuilt? The RV was just driven about an hour down the interstate onl 2 weeks ago and ran fine... ... ... so it is likely the carb is good. I need some help here!
Alan
Alan
