Details here: TDR Privileges
Hi. I will be starting my own Ford/Cummins conv soon, and would like some feedback on a clutch pedal assy. Truck is an auto, and a Dodge 5sp will be behind my 01HO motor.
I used a stock ford manual trans pedal and hanger to make mine. I removed the return spring and the rod that goes down through the floor. I'm using a master cylinder from an '89 Ford with diesel (NAPA). Have to connect the mstr cyl to the pedal and drill a hole in the firewall. I will post some pics when its complete.
I put a plate cut for the second gen clutch m/c on the oem pedal assembly and used the complete NV4500 clutch setup. I had to shorten the rod some. Check my gallery.
