8.3l cummins
check engine light
Help...Autometer EGT Z-series.
does anyone know how to bomb a 1993 8. 3l cummins in a bus, the pump is not the same as the 5. 9l.
thanks, brian
Brian:
What pump do you have, a p7100, a VE44 etc.
Can you send me your engine serial number and cpl and we'll find out if your unsure of what pump you have. .
If it is a p-pump, torq. plates are available for it, etc. .
If its a ve turn the fuel up a bit and get some hod rod injectors, you may have the hx40w? If you have the 16cm2 combo with this , you may not need turbine housing mods to build better low end boost.
I presume you are coupled with some sort of Allison auto trans. , ?
Good luck
Andy
Andy:
I have a 2000 Newmar "Dutch Star" Motor
Home with the 8. 3 Cummins 24 Valve. My
engine has the VE-44 electronic pump but
I am not sure which turbo housing I have.
What is available for this engine?
Thanks for your help!
John_P
