8" suspension lift who has one 05 cc sb
Remove Factory Bedliner & Tiedowns
D25 Coil Spring Rate ?
8" Lift
I have not found anything larger than a 6" for the 03 and newer trucks so I went with the 6 for mine. Good luck.
Full Throttle makes a 10" and Kelderman makes a 8 to 10 I think. Both kits are very nice and very expensive. I to have dreams of a long arm 8" kit and could not find one. I settled for a six for now.
Well I did some check and the 8" kit is only for the Ford superduties. That really sucks. The tallest I can find for your truck is a 5" kit.
If you run a 6" BDS with the long arm kit, you can stack the BDS 2" Leveling kit on top to get a true 8" up front. You will have to get rear springs/add-a-leafs or something else done to get the rear level.
Davey, will you be able to get a good alignment job with this set up? How is the driveline angle and length? Every man would love 2 more inches :-laf
8" lift
I'll have to second Fozzy's question about driveline angles, etc. The 6" BDS long arm is great on my 06 Mega cab but the front driveshaft might be pushing it on length with 8 inches. Be sure to check it all out first. :confused:
