80 DODGE D150 3.9BT
I INSTALLED NEW PANEL MURPHY OIL PRESS ,WATER TEMP DIGITAL TACH ,AIR PRESS ,VACUUM,VOLTS ,TRANS FLUID TEMP@EXTERNAL FILTER CONVERTER OIL OUTLINE ,ENGINE HOURMETER. ,MURPHY WARNING LIGHT FOR LOW OIL PRESS AND HIGH WATER TEMP, ALSO WATER IN FUEL WARNING LIGHT. DUAL BATTERIES MOUNTED IN UNDER FLAT BED TOOLBOX ,WITH ON/OFF SWITCHES, 5 GALLON STAINLESS AIR TANK MOUNTED UNDER BED,2 FUEL TANKS . PRE LUBE PUMP TO DUAL OIL FILTERS ,LF3552 REMOTE MOUNTED . 10 MICRON FUEL FILTER AT TANKS PURLATOR ELECTRIC PUMP LOW PRESS TO ENG LIFT PUMP TO,RACOR 2 MICRON @ENGINE INJECTION PUMP BOTH FILTERS ARE WATER SEPERATORS ALSO.
