Hi guys. I know some of you are very exceited about the new HO 6. 7L engine with 800 ftlb of torque. I see it is only available with the Automatic Transmission. Here is my question. Does anyone know if this torque is electronically limited in first and/or second gear?
Chrysler has been known for making large output numbers (300C with hemi), but all that power isn't put through the drive train until higher gears in the transmission are engaged, other wise drive train components will break. So far 800 ft lbs of torque isn't aiavaible in the manual transmission and I am guessing it is for a couple reasons... . 1. Transmission can't handle it. 2. If the trans could handle it, in low gear, the drive shafts and axles couldn't handle it. This is just speculation until I find out the answer to my first question.
800 X 5. 94(1st gear) X 2. 72 (xfer case ratio) = 12925 ftlbs in the drive shaft and u-joints. The axle shafts would see this X about 4. Needles to say that is a lot of torque.
