I am banging my head on this stupid truck and can't seem to figure out my problem. A few months ago, this truck didn't want to start one day. I was able to jump across the solenoid w/a screwdriver and start and drive it for a while. Then I got the bright idea to try and fix it. I bought a new starter solenoid (inner fender) and tried to install it. Genius me forgot to label the mass of wires that were attached and their order. I finally got it how I thought it should be and gave it a crank. It fired right up but the starter motor stuck engaged after it cranked. I had to disconnect the battery to get it to stop, key wouldn't do it. I looked everything over and tried to connect the battery again and even with key out of the ignition, it was trying to turn over. I gave up for the time being and convinced myself that it had to be something different. Fast forward to today, I dropped a new starter in it thinking maybe something was stuck in the starter motor itself. No luck. I can't find a picture of how the wires are supposed to reconnect to the solenoid but every combination I've tried won't work. After thinking some about it today during a break, wouldn't every accessory wire HAVE to be hooked up to the (+)side of the solenoid going straight to the battery? If they weren't they would only get 12V when trying to start the truck. Three out of the four wires have fusible links in them and one lug obviously goes to the alternator, another one actually gives me dome light, radio, guages, etc. when placed on the (+) side.
If anyone has this model truck or can offer some help, I would greatly appreciate it. This is my stepson's truck and he is fixing to get his driver's license and is chomping at the bit.
Thanks alot,
Wolfman
Thanks alot,
Wolfman
