$89.95 to Cure MPG Woes
Pressure regulator as a boost fooler?
looking for 5" tip
Oh no, not another one of those. The funny thing is you just keep seeing more and more products like this. That means people must actually be buying them. :D
My truck hasn't used a single drop of fuel since I installed 2 of these! Wow, what a difference. I can't believe I was so stupid for so many years.
Not allowing the wide use of these is a plot by the Bush Oil Companies. .
It's got to be true, I could actually see the green balls lining up and marching toward the injector pump. I'm impressed, and you get a free cell phone antenna too!
Oo.
Oh yeah! That cell phone antenna is supposed to be "a 19. 95 value".
I have one I got free. It looks just like the one in the picture. It is a piece of stamped foil with adhesive on the back. I can't tell a bit of difference using it!
I tried the link- site was down for maintenance; maybe they have a 2 for 1 buy to clear out the 80,000 sf warehouse they filled with the things when they were made for a dime apiece.
Daniel
I detect a hint of sarcasm here!
I use this,magnets on the fuel line,tornado in air inlet, and every fuel additive known to man. My truck is so fuek efficient now that I have to drain the excess from the tank between trips to prevent it from bubbling out onto the ground. I am a firm believer in all this ****! Don. :rolleyes:
Be carefull with these - I installed 3 and I have to keep an extra transfer fuel tank hooked up to the overflow that requires every day I go to the Texaco station and dump it into their tank - they give me $1. 25/gallon - so far I've made over $18,000 dollars with this thing... ... . A lot better than the 150mpg carb!
