89 Cruise Control Questions? Need help.
Exhaust System
Broken Frame! 89 W350
Anyone out there have Cruise control in there 89's? Was it a factory option? I am having problems with mine, pulled it out of my
totaled 89 and reinstalled into another
89 truck and now can not get it to work anymore?
Does any one have a correct wiring diagrams
or any suggestions in how to trouble shoot or fix it. Dealer has no info and said that the 89 never came with cruise?
Thanks
93 D250 Club, Banks Exhaust. Stockland shell. 80k
91 W350 Standard. 228k
89 D250 Rebuilt from Total, Banks power pack, wastegated turbo,intercooler,
Gearvendor , 727 3 speed auto, 3:07, goose neck, 5th wheel, Stockland shell.
Flex steel seats. 150k
Thiery are your switches for the cruise control part of the turn signal? I can't tell you if your truck came from the factory with cruise, mine did, but it is a 92. What I can tell you is that in 92 they had 2 different steering wheels, a large one and a smaller one with the control switches mounted to it, this is what I have. When I purchased the truck the dealer told me that 92 was the first year for the smaller steering wheel. It is possible that the cruise control that you have was offered as a dealer installed option. What I would suggest is that you consult the factory service manual, this should have a wiring diagram for the cruise if it doesn't than for shure it was added on. If you can't get your hands on a manual I may be able to help you with the trouble shooting chart in my 92 manual.
Neil
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): bombedcummins@sympatico. ca
Theiry
see you up here saturday
dont forget the tach
i cant wait to mount it , bill
will looking at my cruse on my 93 help?
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach soon to be in. Its loud and goes ok, for a 93,only beat 1 pwr strk furd. 2 optimas,
love driving it!
Thiery, cruise control was a dealer installed option in '89. It was not available from the factory. The system the dealer installed on my '89, (in '89), uses a speed sensor that is driven by the speedometer cable. Did you swipe this part from the totaled truck and install it in the "new" one?
Will have to look for the speed sensor, where
is (was) it located as I still have the totaled truck, minus the wiring loom as it will be used in the make up for a 85 Crew cab
conversion my friend "CudaBob" is doing.
Will need to look at and compare wiring harnesses and sensors to try and figure out what may of happened.
Do you have the wiring scematic by any chance?
Finally got the AC working, last thing is the cruise?
Thanks,
drivers mopars, Thanks for the offer on the 93 but I have one that I will be in on Saturday and it is completely different.
I will be bringing your Mopar 93 tach up as well and you will be able to see mine as it's mounted.
See you later.
I'm curious as to where you got the cruise control. That is one thing I wish my truck had. I would be interested to know how it is hooked up and how well it works. I ask about a year ago for info on this but was told that JC Whitney was selling some but they didn't work well at all. A lot of surging.
90 W250, 5-speed, isspro gauges, 16 cm2, K&N, Borgeson shaft, JRE 3" exhaust
thery, bill thks 4 coming up today
its 7 pm sat tach is in , took 1. 5 hours
did u see the 90 in the lot down the rd
bill
love driving it!
