Can some of the 89 90 owners weigh in here? What is typical as to problems with the controller. Mine don't turn on with the key but I can jump the solonoids and they work. I realize that a momentary switch would work but would like to hear from others as to a "fix" on the problem. I won't be buying a new controller. Have there been problems that didn't involve the controller?
My amp guage is dead. Is this common with the early CTDs? I will most likely install a volt gauge to replace it.
Who has changed the vacuum pump out to the newer style? Looks as though the brackets for the throttle cables would obstruct. Chop the bracket??
This engine seems to have a greater rattle than I am accoustomed to. Have any of you that has had a head off checked the tdc piston highth. Some of the old Macks I worked on occasionally would be slaping the head because the piston would travel a few thousandths too far. I have no reason to suspect a problem with the bottom end. The oil pressure is good and there are only 165k miles on the engine.
Any one needing a 727 before I take it out could drive this one. Works fine. I would like to get some money toward a 518 OD. Or does anyone have an add on OD?
Can the 94 and later automatics be changed to the 518 by installing the 518 governor/control assembly?
Thanks
1stgen4evr
James
Thanks
1stgen4evr
James
