Has anyone given any thought to using the HX35-9cm2 turbo from the 2001 ETC Automatics? The smaller turbine housing would increase throttle response and torque over stock, especially with a custom-tuned pump. I know the operating band of the engine would probably be shifted from 1600-2500 RPMs to 1300-2000 RPMs, but when combined with a LARGE truck transmission (7,9,10,13-spd), you pull a house down. This is a step in the opposite direction from the high horsepower crowd (increasing RPM), but the available fueling at the lower RPM would be phenomenal. Is there a 9 cm2 turbine housing available at this time? Ted Jannetty, I'm sure you'd be a fan of this set up!
-Michael
'00 2500 RAM, RegCab, 4x2, Cummins, 6-spd, Driftwood/Agate...
-Michael
