-90 Burb is going to get the C
'95 12V engine in '98 24V Auto truck issues...
Want to dump V10 in 2000 Ford Excursion
Matt, titanium is great idea, would you be my sponsor... :-laf
More rough down cutting has been done to the crank, few are still undone. Gotto postpone the crank thing since I started to soda blast my burban. Paint has seen it's better days years ago, sun blown, peeling etc. Started to blast it last week in the evenings after work, hoping to get it ready for priming on next week. could post some pics of it next week as well.
Cheers
Timo
Few shots of burban under work. I blasted it with soda, got it primed and top coated door openings over the weekend. Today we haul it off to a painter, should get it back at the end of this month. Ones back together it's time to continue the crankshaft thing again.
Timo
Been awhile since last time I was here. Well burban got painted and driven around allot. Although it's now got an empty engine bay. Took the engine off to put in lightened crank, what I started to mod years ago. It's now bolted back in the block with cam etc. minor parts. I think test run would be in a two months. The first start up is going to happen back at work on a test bench. More of the build up on The DevilsCastle.net Cummins-project and on the other forum too, under extreme engine tech. Got only one pic of the burban on my laptop, it's partly put back together but good enough to see how the color turned out.
Timo
Hey there I've been in the midst of a Cummnis Swap in my 88 GMC R3500 and was sent you templates for the motor mounts, and was curious if you had printable version of them available I looked them over and would really like to use them in my swap Thanks and God Speed
I do have One Question. The Template Zip Files... are those, when printed at 100% at 100% size or are they atta different ratio somewhere like 90% I'm planning on having a set cut out for myself around the 3rd of March
