9000's or rear sway bar? whats better?
Difference between Fiver and a Gooseneck?
Gross Weight??
i have a 93 4x4 duelly w/ lance 11 'camper\
has factory overloads, 9000 rancho in front
stock rear no changes.
Whats better to contol side to side movement? 9000 's inrear or hellwig rear sway bar, i cant affort to do both at once.
do want air bags,dont need them
mopar bill
1993 w350 ex cab, banks,nv 4500 in
open exaust, pw Injectors are in. Big rig flaps,tach soon to be in. Its loud and goes ok, for a 93,only beat 1 pwr strk furd. 2 optimas,
love driving it!
I just installed a 1. 250" rear sway bar on my rig. Man what a difference. It now feels like an empty pickup while driving. No sway whatsoever. Check out my website and you'll see mine is a bit topheavy. I found a used front bar off a class A motorhome and made up my own attachments. If you have no sway bar now, you will notice a huge difference with one.
1972 Chinook class C with 96/215 5spd, 4/5" exh, 4"BD, MagHytec, 85gal fuel, K&N RE0880, AutoMeter, 370's, BD gov kit, BD afc kit, 16cm, 16%btdc, yada-yada-yada
www.fostertruck.com/cummins
I vote for a sway bar as it's intended purpose is to prevent rocking from side to side and shocks are suppose to limit the up and down bounce. This doesn't mean that the 9000's on the rear wouldn't help.
drivers mopars The Rancho 9000's made a big difference for up and down,and side to side movement,over the factory shocks. I didn't feel good about leaving it that way because of what the truck was going to be put through. One thing I did to the truck in addition to the shocks was pull the factory overloads out,and replaced them with a 4 spring stack on top of the main spring pack. Unloaded the truck maintains the factory ride. The way the truck is set up now, loaded it rides as firm and as stable as my wife's 1500 4x4. My Lance's weight is just about 3500 lbs. We just finished driving from Alaska to South Carolina,with the camper and towing a trailer. The truck worked great. I keep the Ranchos set at 3 in the rear and 2 in the front when loaded. I sold the airbag set I had left over from a Ford I had because they we're a pain in the butt. I decided to do this truck right. I think the airbags are a cure for doing something half way. The springs cost $75 more to do but they won't leak.
2K Dodge 3500,4x4,SLT,Quad Cab,PR4 Red,Auto Trans,354's,Posi,Trailer TowPack,3 Piece Auto Ventshade Hood Protector,"BEEFED" up Factory Camper Pack{No Airbags},Factory Fogs,Rear Slider,Rancho 9000's,Rhino Spray In Liner,Smitty Built Nerf Bars,Alpine 60x4 Watt CD Player,Lance Cabover Camper,BD Plug n Power,EGT Guage,And Enjoying The Ride.
2K Dodge 2500 SLT RC LB PB3 Blue
99 Dodge 1500 SLT/Sport RC SB Solor Yellow {Her Truck}
