I found a 91. 5 CTD today and picked it up for my son. He is currently deployed to Afghanistan, so I did the leg work for him. It's a one owner pickup with 190,000 miles. The owner is 70+ and just didn't need it any more. It has an automatic transmission and is totally stock. The only thing I can find wrong so far is that it has a couple of electrical issues.
When driving, at times the 'wait to start' light flashes for a while and it won't shift into OD. When the light is out, it shifts fine. There's no pattern to the light coming on. It was 98 degrees today and the light would simply flash several times intermittently while at highway speed, then go out for a while, repeat, etc.
The blower for AC/heat is also having issues. There is no power coming to the blower switch. I checked for blown fuses and they are OK. There is power coming into the control panel, as the compressor does engage and functions correctly. You can feel the cool air being pushed in when cruising, I just have no power to the blower. I hooked a jumper wire to the plug and have all three speeds on the blower, but no power to the switch, if that makes sense. In the morning, I will finish pulling the panel out and see where power is supposed to come from.
I swapped the ignition switch out with a spare, but no change. Thanks and any ideas will be appreciated.
Bud
Bud
