This is the sometimes it does, sometimes it doesn't OD. Flashes water in fuel and wait to start lights, but it's not the OD solenoid on this one. Does the same thing with the solenoid unplugged. And I cut the wire from solenoid about 6 inches from computer just to make sure it wasn't a wiring harness problem. Flashes lights also with water sensor and TPS unplugged. Lights will flash when truck goes over a good sized bump which indicates some mechanical connector failure, but I haven't been able to relate any other condition to light flashing. It will drop OD when lights flash if it has gone into OD to begin with.
This is making me think I've got a bad engine computer. This truck doesn't have a check engine light so I can't pull trouble codes that way. How does one pull trouble codes on this model? '92 FSM hasn't helped with that. It lists codes, but doesn't tell how to get them other than check engine light.
Any idea if '92-'93 engine computers interchange? I'd think that they probably would and those will apparently feed a check engine light among other things. '93 replacements also seem to be a lot lower priced.
