'92 D-250 transmission help
Kill the Cat?
Engine Serial Number Location
hi there i'm new here. well anyway about a month ago i bought a 1992 d 250 std cab 4x4 cummins ,well this past sat. the transmission took a dump,automatic, (the truck won't move) my ? is i really don't want to rebuild so where is the best place to buy a transmission? and what options do i have ,what have you guys done i was told when i bought the truck that dodge's trans. were junk , is there any one who builds a good ?
Look down the page real quick to a subject
"Automatic Transmission" and read the reply
from Bill Kondolay. He's an expert in these
things.
Too bad he's so far from your place in NC
and mine in VA.
92 D250 LE ClubCab, pump-tweaks, tach/pyro/gages, 16cm2,
A518, 3. 54, LSD, TowPkg, SuperDuty cooler, RBW 5er hitch.
00 Jayco 27' 5er
If you have only had this truck a month, do you know its history (what sort of care it had). Could it be a hung brake(frozen wheel cylinder). With the truck in neutral can it be move. Has the transmission pan been removed to see if it has a lot of metal in the fluid. Just some thoughts.
Gene
