HELP! I'm swapping to rear Disk Brakes on our '92 D250 CTD. All the new stuff is connected. The system has been bled, but I cannot get enough pressure to the rear brakes to stop them from turning while under power. (Rear tires are still off and jack stands holding truck up) I have to pump the pedal several times to get them to stop. I have a "MOTIVE POWER BLEEDER" and have pumped well over a quart of fluid through both rear brakes. All the old stuff is out, only new brake fluid, no bubbles. The manual states to bleed the RWAL Hydraulic valve. I CANNOT find the valve. I know it's there because it has worked for us. HELP please.
