92 timing adjustment
12cm turbo housings
Tranmission cooler - Please help
MY 92 seems to need an adjustment to the timing can this be done with out removing the pump. If so please give some detail.
Yes the timing is done without pump removal. It can be a real booger to do and while I've turned a few wrenches in my time I let a trained person do mine,, but thats just me.
There are some who can work real magic on this, with extreme exacting settings. The engine has a TDC 'pin' which is not very accurate, and TDC is were this whole process starts. You will need a remote mount dial indicator just for starters, not to mention wierd twisty shaped wrench to get at one of two of the pump mounting bolts... this is why I shelled out some zooleks to get it done.
FWIW ;-)
Regards, Bush'
