The cover on the back of the injection pump came loose and the seal blew it finally started to spray fuel that's when I knew I found the problem so I pulled the pump and I had it resealed the engine was still starving for fuel at wide open throttle so I replaced the lift pump and solved that problem to .
Thanks for the replies and the help
Shaun
Shaun
