'93 club cab 4x4... fuel tank capacity?
Timing and valves
2 more questions
... my '92 is supposed to hold 30 gallons and the light to come on with approximately 6 gallons to go.
I regularily go 500 miles before refilling 24-25 gallons or so.
Don't know how you tell for certain. . don't like to run it dry.
gary
'92 W250 LE 4x4, NV4500 5spd, Borgeson steering shaft, PrimeLoc
I wish I could go 500 miles on a tank. And I thought 400 was doing good.
Dan Powell '93 club cab 4x4 4" lift, 315 75 R16 MT's
'87 Buick Turbo T
11. 52 @ 117. 5 mph
According to the owner's manual the 92 holds 30 U. S. gallons. In addition the Low Fuel light is set to come on when the fuel level reaches approximately 1/6 of the tank. I can also easily drive 500 miles before refilling.
92-LE,4x4,5spd,3. 54,Borgeson steering shaft, Tach,Isspro Pyro & Boost, 16cm2, PW injectors
I notice my owners manual says my fuel tank should hold 29 gallons. Every time I fuel up it only takes 23 gallons to fill, even after the low fuel light comes on well into the red on "E". I usually go almost 400 miles on a tank. Sound right?
'87 Buick Turbo T
11. 52 @ 117. 5 mph
