I am replacing the clutch in my 93 work truck(265K) with a SBC Con O. The clutch release arm and pivot ball were polished, not galled, but starting to groove out; so I ordered a new pivot ball at my local dealer. I received a ball that is plastic on the top half. I didn't think it would stand up long in the polished but grooved release arm, so I ordered a new release arm. 1)How long has Dodge been using this plastic pivot ball, and does it last very long?
DPuckett has posted that, at least in high milage CTD's, we should replace the cam plug in the block any time the clutch is replaced. The cam plug shouldn't move or deteriorate unless there is excessive wear on the thrust plate under the cam gear should it? 2)What has been your experience/observations on this potential problem.
The rear main seal on this truck is absolutely dry. 3)Should I be replacing it
now?
Thanks,
Mel
now?
Thanks,
Mel
