93 D-250 Fuel Pump Replacement
Did I hear 400hp 1st gen with hx35??
New Weatherstriping
The manual priming lever on my mechanical fuel pump (located between the fuel filter and the engine on the drivers side) is no longer functional, and I've been told I have to replace the whole pump. I was flaky the last time I used it an now it has no resistance at all in it. Can't replace and prime the fuel filter otherwise. I know I have to rotate the crank to top center to make it easier to get off/on. Does anyone have any other helpful suggestions/procedures to follow? I suppose I'm lucky, 233,000 miles and first fuel pump... and/or part numbers?
AND. . MFA has sagged the drivers side of my bench seat to the point of causing permanent spinal disfigurement! I know this was a fault in the truck for everybody. Any good ideas for fixing the seat-sag?
Be sure that the engine's cam shaft lobe is not in the high position. The pump will not operate in manual mode if it is.
A low profile hydraulic jack and 2x4 will work well for seat sag.
GL
ps gitcha the "sexy" piston lift pump and no-mo primer lever problems ;)
