Yep. Dead in the water with the '93. Let me know if you think I'm missing anything. I'm not stuck and I've got a clean dry place to work on it. But if anyone knows where Lakeside MT is and wants to get their hands dirty... .
The truck was moving along just fine and pulling a light load. I was having a hard time keeping speed as if it was getting less and less fuel over the duration of a 400 mile trip.
Started making a sound like it was shifting out of overdrive. Just more engine noise. Definately not transmission. I had the OD off and it would do the same thing.
Coincidently, I got fuel 10 miles before this happened. Truck just cut out as if it ran out of gas. Dropped to idle and then shut down.
I pulled the banjo fitting at the filter. Fuel splashed upon cranking so I THINK the lift pump is good.
I get no fuel out of the banjo fittings at the injector pump and no fuel at the injectors.
I checked the wires to the fuel shut off solenoid and its all connected correctly.
I'm open to ideas but accept that the pump is history. New pump should be here Thurs noon at the latest.
