93 intercooler specs...
NOS parts for 92 & 93 D/W350
Solution: The door hinge problem
Here are the dimensions for the intercooler out of a 93 model. This may help if you plan to build your own.
Part No: 52004274
Weight: 20 lbs
Tubes: 18
Fins per Inch: 12
Width: 37"
Height: 12 3/4"
Core Thickness: 1 5/8"
Inlet ID: 2 1/4"
Inlet OD: 2 5/8"
Inlet/Outlet Center to Center: 34 5/8"
Inlet Vertical Center: 6 3/8"
Inlet Length (from core): 4 1/2"
Attached: image 1 of 2... Thanks to OkieBroncRider.
Link to original image:
Bob.
Dimensions for Intercooler out of 94-02 CTD:
Core size 36"x16 1/2" x 2 1/4" Thick.
Lower mounting insulators center to center, 39 1/2"
Inlet to Outlet center to center, 41 3/4"
Upper mounting eyelets center to center, 45 1/2"
Inlet & Outlet OD. 3 5/8", ID. 3 1/4"
Image 1 of 1:
Link to original image: Thanks to OkieBroncRider.
Bob.
I didn't put a second gen in my 93 crew but it's pretty dang big.
width 36"
hieght 12"
thickness 3"
inlet and outlet 3"
with 3" pipes coming off the turbo up to the custom 3" inlet for the intake manifold.
Man what a difference that made, I noticed an increace in power and fuel economy but now I have a problem with my fuel pedal "sticking" to the floor. Maybe if I crank up the power a bit more I will be satisfide and back off the throttle... ..... THERE'S NO CHANCE OF THAT HAPPENING!!
